Engine surges to 3 - 4 k then dies
  • Engine surges to 3 - 4 k then dies
    I just replaced the steering hydrolic lines, had to drop the engine
    I also had the intake off.
    Should run fine like before.....
    95 MC Z34 Black
    So it surges on start up in park? Brake boosted hooked back up? Time for C4 and a flame thrower?
      yeah, brake booster hose......
      Ben, i just bought some new magnaflows, so the oil cap is on hold.
      95 MC Z34 Black
        If you removed the intake then in other words Time for new intake gaskets.
        I am back
        Mechanical/Service Technican
          sounds like either a massive vacuum leak or a massive tps signal problem. codes?
            last time i had a vac leak like that turns out i forgot to tighten the bolts from the upper intake manifold to the intermediat arm! i had them hand tight and in the confusion of redoing my FWI at the time i never squezed my hand back in to tighten them... i think it was you dohcfiend that told me to check there... and BamB! it was fixed
