TDC Stop
  • TDC Stop
    Hello all.
    I checked the site and didn't see any reference to this so I'll throw it out for discussion.
    My daily driver is a 1992 Z-34 5-Speed. I purchased the vehicle a couple of years ago. At that time, the engine had been "rebuilt" and a new GM clutch installed. I put the term rebuilt in quotes since there are many different definitions for the term. Ben probably remembers exchanging some communication with me in late 2004. - I am from the Warsaw area too. Since owning the vehicle, it has had a noticable vibration at idle. The vibration is such that the manual transaxle sounds like a can of rocks when idling in neutral. After acquiring the vehicle and noticing the vibration, I had the vehicle scanned but all appeared normal. The vibration has been consistent although slightly worse (since putting on 44k miles).
    I am fairly confident that the cam timing is slightly off. Although I have done a decent amount of work on the 3.4L, I have never had the heads off of either of the two engines that I own. I am planning to turn up a tdc stop that can be installed in the #1 spark plug position. - Do any of you know whether or not a piston stop would interfere with the valves if used while the existing belt is still installed? I need to perform the belt change anyway but would like to confirm my suspicions before tearing down. I would also like to receive some comments regarding the -6 / +6 cam timing configuration that is mentioned on the site. I drive the vehicle about 100 miles daily so reliability is an issue. Thanks in advance for your help.
    joelbob
    If you want to know what your timing is now, we can test your front bank easy enough. I have an adjustable timing tool that will tell you what your timing is. As far as the stop goes and interfering with the valves, they shouldn't hit but I wouldn't time it with that down in there. To compare TDC with the timing mark would be interesting though.
    I think I remember talking to you about it, but yeah, its been a while:P
