broken or not???
  • broken or not???
    got to looking at the alternator mounts on the engine i have and the lower bolt hole looks broke to me but i just want to make sure it really is. heres a pic.
    is it broke???
    92 Lumina euro 3.4 DOHC 139,XXX miles
    yep, it is supposed to be in a shape of a U.
      Just looked at my pics I had of when my engine was out. You can't really tell, but if you really look at it you can tell it is supposed to have a U shape.
      So it isn't broken.
        Cant you tell if the metal has been broken?
        If it bolts up and stays firm ...
        95 MC Z34 Black
          Cast metal will fracture and have a rigid look across the fractured plane.
          Hardened materials and most alloys stress and have fissures and discoloration along the brake.
          I am back
          Mechanical/Service Technican
            well it does look kinda broken along the edge but i just wanted to be sure. i think ill get an alt. and mount it to see how it holds up and go from there. thanks.
              It's definitely broken. Unless there is another design. This is from a 95.
                well that ends all confusion, its broke. if it wasnt so hard to get one off id go to the yard and get one. o well ill just see how things go. thanks.
                  someone probably cranked it down too hard.
