So the car is running good.
Five oil changes in about 5 thousand miles.
Tranny Flush, Brake Flush ect.
New engine rebuld, new tranny, brakes, suspension, ect.
Lifter tick is now gone
Runs pretty strong, likes the RPM's from 3.5 - 6.2k.
Disk brakes stop on a dime, lowered suspension looks and feels good.
But,
1. AC compresor wont turn on, slow leak but was at pressure.
2. Regular air will only go to feet.
3. Temp sensor reads 210 degrees all the time from scanner.
4. Panel temp gauge works properly. must be two sensors.
5. I have to turn on AC switch to turn on fans, so they are pretty much on all the time.
6. Low hummmm from right rear tire area when brakes are first applied.
7. Aftermarket gauge reads rich at all times, not wide-band.
I do have gauges with Trans temp and oil pressure. I know when to turn on fans when oil pressure goes down from 50 psi at idle.
I know I need to fix Temp gauge cuz I pulled the hell out of the wires trying to get it to stretch, oh well.
I think that is realted to my AC compressor problem?
Air blower does not change direction ie floor to panel to defrost hmmmm.
I think the radiator fan problem is from the temp gauge as well.
But what the hell is the growl from the rear? I guess maybe the knuckle / hub from the junk yard has a bad bearing? Seems to be getting better, but it will also do it a little on left turns more.
All in all I really don't care too much at this point, I am just happy to be driving around after three years on the project.
Next on the list:
Fix annoying problems.
Magnaflows
Wet flow head w port job.
Headers.
Tires.
New paint/tint.
Maybe this Wednesday I will take it to Infinion if they are not racing.
But,
Next on the list:
Magnaflows
Headers.
Tires.
New paint/tint.
