Need to know
  • Need to know
    Can I replace a 3400 SFI with a 3.4l dohc in my 03 Alero or with a 3800 supercharged what all would I have to move or change thank u for time and consideration in this matter
    Sent from my 831C using Tapatalk
    How well can you weld and fabricate?
    Overall,not my first choice for engine swaps.
      No welder but am ok at it
        What would you recommend
          I'm OK at it but don't have a welder on hand I already pulled 3800 supercharger on it and headers but what would you recommend
            Should I use the 3.4 liter DOHC I've built a lot of classic muscle but this is my first transverse motor don't know if I should go with a supercharger or turbo
              I agree about the 3.4 DOHC. I had one and wasn't impressed.
              It's obviously a taller engine and hugely expensive! Every OHC engine I've owned are expensive!
              Personally, I'd leave the 3400 in the Alero and just build it!
              Ben Lujin
                So half way there motor is in mounts made sensors wired adjusting header now to swap pcm and bum how can I get a pinnout for 03 alero bcm
                  I don't know if your engine cradle has all the proper mounts for a LQ1. Post a pic of one and all let you know if it will bolt up or not. But I'm betting the rear mount is missing in a 03.
                    I put in a l67 series 2 I've made new mounts have it in but need wire diagrams for the ecu plugs on the stock 03 alero 3400 sfi so I can wire it to a 97 or 98 grand prix 3800 sc ecu
