DOHC Stall at 3000 rpm
  • DOHC Stall at 3000 rpm
    Our 92 GP 5-speed 3.4 will not accelerate past 3000 rpms in all gears. I think I have tried and replaced everything!!! Is there a solution I am missing?
    Is it hitting a rev limiter or does it just not go past 3k? Is it setting any codes? Have you messed with the computer or wiring before it started doing it?
      No codes are set and it misfires or stalls at exactly 3000 rpms.
        Check backpressure, or unbolt front of cat and run car to see if any improvement this sounds like a possible plugged catalyst.
