The GTP Build
  • The GTP Build
    Hi, my name is Clay. I live in Omaha and am friends with the forum member "Huskey".. Were working on rebuilding his GTP. Its pretty rough right now. Let me know what you think. Ill also include as list of parts we still need if anyone has anything laying around youd like to get rid of. Thanks!!
    Engine/Suspension Components:
    Shift cable/select cable (On order)
    Engine wiring harnes (96-97 LQ1)(received)
    UIM (96-97)Bought
    LIM (96-97)bought
    TB/arm (96-97)
    Throttle cables
    EGR Setup (will by-pass)
    Head (96-97)
    Exhaust manifolds w/crossover (96-97)
    Oil Pan (96-97)
    PS Pump (96)
    Timing Belt and tools-bought
    Dip Stick-bought
    Interior:
    Inst.cluster (96)
    OBD II DIC
    Carpet(Black, Grand Prix)
    Seats(???)
    Dashboard(Black, Grand Prix)
    Headliner(Black, Grand Prix)
    Door Panels(Black, Grand Prix)
    Rear Sides(Black Custom/Dynamat)
    Rear Deck(Black, Grand Prix)
    Shift Knob
    (This is copied off my thread started on a SHO forum as thats what i own! )
    Well.. we started tearing into the GTP pretty good.. ill get some more pix when i can get them off my other computer BUT so far i have the tear down of the motor!!
    Intake Manifolds off
    Timing Belt.. Goofy, hugh?
    Cam Carriers
    Teh Head.. under the cam carriers.. these motors are goofy as ****..
    Some Pistons
    This is the Piston where the head gasket showed some bad wear..ogle:
    Rotating Ass..
    A fun vid.
    Clayton
    1994 Ford Taurus SHO MTX
    nice tear down... that is a dirty motor lol... would love to see pics of the progress as you make it. Good luck with the rebuild. how far down are you taking it? If you do a full tear down to the block i would like to see the block all hot tanked and clean.. i hate working on greasy ass motors, makes such a mess.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Weve already put it back together.. What you saw in teh pictures was as far down as we took it. We cleaned a lot of the gunk off and just rebuilt it from there with all new gaskets and seals. Currently the motor and tranny (were doing a 5 speed swap and OBDII swap) are back in the car! Even tho were going a step further and redoing the motor im sure its going to come back down in the next couple of weeks and were going to take the motor completely apart, but ill let sam (huskey) Chime in in the next few days here!! If you guys have any suggestions that you would like to say we are open to anything and everything! Thanks!!
      Clay
      Clayton
        I have so many DOHC parts...block, cams, carriers, intakes, etc. I don't have a complete 96 upper but I have an upper, and a broken lower (yipee). I have a good 96 upper but I think my only lower has a broken bolt hole in the flange area. Not sure how bad any more. Some parts are on wot-tech in the clearance section.
          Nice tear down. Yea, that is a dirty engine! Happen to get it all cleaned up when you put it back together?
          I have a 96 Monte Carlo 3.4L DOHC Engine bay harness w/ injector harness, rear O2 wire harness, PCM and PCM box $125 shipped. Let me know. I also have the throttle cable. Like new throttle cable. I will throw it in for free if you happen to get the engine bay harness.
            Let me know how the tuning goes with having OBD II and the 5spd.
            I would change my car to OBD II if I could have it work fine with my Getrag.
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
              Its fine, my 92 has this setup already.
                Its been done a bunch of times by l67 guys.
                  Well.. we cleaned up the garage tonight cause it was a PIT. ill up load some b4 adn after pix in a while.. IMHO were missing a lot of parts.. but well see what sam says!! :/
                  Clayton
                    Ok.. we changed our minds
                    We decided to take the cradle out....again and tear the motor down again and do this right. Were going to get all new everything (other than block pistons crank etc..) new bearings seals rings gaskets etc tho. Were going to power wash the hell out of the 284 and get the block and heads hot tanked!! Ill have pix up tomorrow!
                    Clayton
                      Yup. The day was spent cleaning up today, but tomorrow! Tomorrow will be spent... Yeah, tomorrow will probably be cleaning too.
                      BUT NEXT WEEK!
                      Hopefully we'll be down to a bare block next week, which will get loaded into the trunk of my car, and taken to Daly's to get hot tanked. The rest of the parts will get cleaned manually, before reassembly. Pics and info coming soon.
                      1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
                      1995 BMW 540i, Alpineweiss-III, 6-Speed
                      1995 BMW 540i, Schwarz-II, Automatic
                      2004 Honda 919, Light Silver Metallic, 6-Speed
                        Pix added
                        Here are some updates!
                        thats with the main caps off
                        We called it quits at 230 am! My goal for the night was to get the whole block torn apart.. We were short by 12 bolts! :/. Hopefully we can get it stripped all the way in the next few days and get it off the the machine shop for some cleaning!
                        Clayton
                          sexxy
                          Shane "RedZMonte"
                            Nicely done sirs! I'm going to be watching this thread very closely
                            1992 Pontiac Grand Prix SE - black/charcoal, 3.4 DOHC, 5-speed, 171,xxx miles
                            1991 Pontiac Grand Prix GTP - blue/charcoal, 3.4 DOHC, 5-speed, 153,xxx miles (parts car)
                              When it starts going back together, I would throw a 2x4 under that crank pulley so that stand doesn't collapse and take off someones toes making for a very bad evening. I have that same stand with a 95 engine on it and it leaned as well (but not that bad) and the 2x4 is how I fixed it. As long as mine has been on there I bet it would have broke the stand by now had I not put wood under the pulley.
