3.4 DOHC rebuild for z34
  • #16
    Lol also the car is a 93 lumina z34
    • #17
      Thanks for letting us know where your coming from.
      A person will need to break this into sections though, I'll you a send a list............
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
      • #18
        thank you very much that would be greatly appreciated.i cant wait to start rebuilding the engine.
        • #19
          feel free to post it right in here i and some other people are probably interested also
          1994 Lumina Z34
          • #20
            Yes make sure you do, because the more info you get, the more it will help you to get started and hopefully answer all the tons of questions I'm sure you must have.
            We can all offer you a lot of pointers.......
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
            • #21
              ok thank you a lot.while the engine is apart aside from rebuilding it i plan to do engine work to do also.this would include,5 ngle valve job,port and polish,ported intake,nitrous also some others i cant remember right now lol but yes the sooner the better for the list.also thank you very much again.
              • #22
                I hope you have a deep pocket book. Porting is expensive, and can trash a set of heads if not done right. Also if you're not going with custom rods, or the 327 SBC rods, have your stockers shot-peened and have the rotating assembly balanced.
                • #23
                  327 sbc rods are a direct fit?????????????
                  1991 Grand Prix STE
                  3.4 DOHC
                  1 of 792 Produced
                  Extensive Mods Done
                  1991 Lumina Z34
                  3.4 DOHC
                  Getrag 284 5spd
                  1 of 30
                  • #24
                    im not too worried about anything money wise because im not in a rush too do it. list?
                    • #25
                      No, the big end needs machined narrower, but otherwise are the right length and both end bores are the right size.
                      • #26
                        Has many used these 327 connecting rods this way and had them work fine? If so, that would be a much cheaper way of getting light "H" beam rods for a 3.4 dohc then having a custom set made...
                        They still do cost a good buck though..
                        1991 Grand Prix STE
                        3.4 DOHC
                        1 of 792 Produced
                        Extensive Mods Done
                        1991 Lumina Z34
                        3.4 DOHC
                        Getrag 284 5spd
                        1 of 30
                        • #27
                          I don't recall anyone running them, but I do recall the talks about them being identical floating around, just wider on the big end. But yeah, I wouldn't mind having 2 to put on the shelf vs the price tag on a full custom set of 6.
                          • #28
                            Custom made rods can be VERY expensive... over $1k for the set. Narrowing a set of 327 rods should be cheaper and work quite well for most setups.
                            Tim
                            325 whp 350 lb-ft
                            • #29
                              Yep! I wish there was someone who tried they already............
                              1991 Grand Prix STE
                              3.4 DOHC
                              1 of 792 Produced
                              Extensive Mods Done
                              1991 Lumina Z34
                              3.4 DOHC
                              Getrag 284 5spd
                              1 of 30
