Found a black 92 GTP at the local pick n pull
  • Found a black 92 GTP at the local pick n pull
    Looks like it had a minor front end crunch, rad is pushed in about an inch. Engine should be good but the timing belt was heavily frayed. Has a 40t60e and the LQ1; was hoping for a 284. Already missing the maf, iac valve and front valve cover (me). The body panels are no good. Has dark leather seats but are in rough shape. Possibly going back on thursday or friday so if any one needs some parts I can check it out.
    MAF sensor?
      where do you live?
        Originally posted by 5speedz34 View Post
        MAF sensor?
        MAF Sensor was gone when I got there. and the IAC valve. I pulled the front cam carrier cover off and it's currently getting powder coated. Tried to pull the main rad fan but it had a bearing squeak so I left it. Got a few trim pieces. The GTP badges were also gone.
          Originally posted by gpchris View Post
          where do you live?
          Kelowna BC.
            What I meant is the 91-93 car's never got a MAF. They had a MAP.
              my bad, I meant MAP, either way it's gone.
                Quad Buckets?
                  Originally posted by webxfx View Post
                  Quad Buckets?
                  It has quad bucket seats but they are leather and need to be recovered.
                    what color any ways? want to guess Brown...
                    I guess I'll just keep watching localy
                      Went back today and pulled the HUD out for $9.99. The seats are charcoal grey; some dick pulled the rear seat and cut squares out of the flat parts in all the other seats to get the leather.
                        what color carpet is in it? what color front seatbelts?
                          Dark gray seatbelts, dark grey carpet (charcoal)
                            i'll upload a pic or 2 over the weekend and if it matches the interior in them, can you pull a few interior parts for me? i'll re-imburse you for labor.
                            most are easy.
                            1. one of the little coat rack fingers in the back of the car
                            2. both of the little ashtrays for the back if you cen get them out without breaking the tabs
                            3. the passenger (or driver) side plastic thingy for the seatbelt. it is where the seatbelt meets the doorpanel, it is plastic, and is held in by 2 phillips screws
                            4. the carpet
                            5. both front seatbelts plus you have to tell me how to remove them b/c i do not know.
                              No worries on the labor it only takes a minute to pull this stuff
                              I already pulled the seat belt covers thinking mine were scratched they weren't and either were these.
                              I can get the ashtrays out for sure another GP showed up so two out four should be good.
                              The carpet is heavily soiled so I don't think you would want it, but I'll look again
                              I didn't see what condition the seat belts are in, but I can look. My light gray belts were quite dirty but I restored them with oxy clean, the look new again. The belts are easy to take off but you have to pull the door panel.
