94-96 Wiring Swap-obd1.5--obdii
  • 94-96 Wiring Swap-obd1.5--obdii
    I am currently doing my swap on my 94 and need some help from the guys that have done this swap. Shane(redzmonte) has helped me out a ton, but since he has a 95 the wiring is a little different. I have the Gm book with all the wires from teh C100 connector, but there are a few that are different from 94-95-96. Please help me if you can. Also on my 94 I have a two wire ALT, black and brown, on the 95-96 its a one wire , red. Anyone know why this was changed and what I need to do to make it work. Both ALT's are the same.
    Here is what I have
    I will post soon
    94 Z34
    Pst/color/ Description
    A1- Blank- Na
    A2- Gry- Fuel Pump
    A3- Pnk- Ignition Switch To Fuse Block
    B1- Red- B+ From #1 Component Center
    B2- Blank- Na
    B3- Yel- Ignition Switch Start Feed To Transaxel Range Switch
    C1- Blank- Na
    C2- Blank- Na
    C3- Lt Grn- A/c Request
    C4- Lt Grn- Back Up Light Feed
    D1- Blank- Na
    D2- Blank- Na
    D3- Yel/blk- Low Coolant
    D4- Wht- Tach Output
    D5- Lt Grn/blk- Park/neutral Switch Output To Rear Compart Release Sw Itch
    E1- Blank- Na
    E2- Brn/wht- Switch Ground For Charge Indicator
    F1- Blank- Na
    F2- Tan- Oil Psi Indicator
    G1- Org/blk- Chime Module Ground For Automatic Door Locks
    G2- Dk Grn- Coolant Temp Gauge
    H1- Blank- Na
    H2- Blank- Na
    H3- Brn/wht- Pcm “mil”
    H4- Dk Grn- Pcm “vss”
    H5- Wht- Cruise “engaged”
    J1- Wht/blk- (vin T)- Pcm Data Link
    J2- Blank- Na
    J3- Ppl- Brake Switch Feed For Auto Trannys
    J4- Tan- (vin X) Orn (vin T)- Data Signal “uart”
    K1 -red- B+from #1 Fuse Block And Ignition Switch
    K2 -orn- (vin X)- Ign 3 Feed To Underhood Ele Center #1 (vint T)- Ignition Sw Itch “ign 1” Feed To Underhood Ele Center #1
    K3- Blank- Na
    L1- Red- B+ From Underhood Ele Center #1 To Ignition Switch
    L2- Blank- Na
    L3- Red- B+ Feed Underhood Ele Center #1 Igntion Switch
    95 Z34
    A1-blank-na
    A2- Gry- Fuel Pump
    B2- Wht- Cruise Control Engage Signal
    B3- Pur- Theft Deterrent Relay Output
    C1- Blank- Na
    C2- Orn/blk- Park/neutral Switch Signal
    D1- Dk Blu- Fuel Enable To Theft
    D2- Wht- Stop Lamp To Cruise Control
    D5- Lt Grn/blk- Park/neutral Switch Output To Rear Compart Release Switch
    E1- Brn- Engine Oil Level Sensor
    E2- Brn- Switch Ground For Charge Indicator
    F1- Brn/wht- Low Oil Level Switch Output
    G1- Brn- Cruise Control Cutoff Output
    H1- Gry/blk- Cruise Control Resume/ Accel
    H2- Dk Blu- Cruise Control Set/coast
    H5- Gry- Cruise Control On/off
    J1- Dk Blu- Transmission Select Switch
    J2- Blank- Na
    K1- Red- B+from #1 Fuse Block And Ignition Switch
    K2- Orn- (vin X)- Ign 3 Feed To Underhood Ele Center #1 (vint T)- Ignition Switch “ign 1” Feed To Underhood Ele Center #1
    K3- Blank- Na
    L2- Yel- Trans Range To Thet Deterrant
    L3- Ppl- Fused Feed To Range/park/ Neutral
    96 Z34
    A1- Pnk/wht- Stop Lamp
    A2- Gry- Fuel Pump
    A3- Blank- Na
    C1- Wht- Electronic Orrifice
    D5- Lt Grn- Park/neutral Switch Output To Rear Compart Release Switch
    E1- Pnk- Ign #1 Feed To Fuse Block
    J1- Blank- Na
    J2- Ppl- #2 Serial Data Communication
    K3- Blank- Na
    L1- Black- Na
    L2- Yelblk- Trans Range To Thet Deterrant
      As you can see on the 94 does not have
      -B2,B3, D2,E1, F1, G1, H1, H2, H5, J1,L2,L3.
      I think that H5 from 94 has to be switch to B2 on the 96. From the 96 E1 needs to be switched to A3.
      I dont know what to do with the others? Any one have any ideas.
        It looks like alot of them that are not active from the 96 are blank on the 94, such as,
        b2,d2,e1,f1,h1,h2,j1
        -I am wondering what G1 from the 94 goes to on the 96
        -You need to add 12v constant to L1 for the 96
        -You need to switch E1-A3 for the 96
        - Is L2 on the 96 the same as the B3 on the 94?
          The B2 on the 96 harness is INCORRECT. I need to do some research and find out what pin the cruise control wire is.
            ONe wire that I need is the 96 cruise control wire, color and position on the C100. Also I looked up the ALT wireing and I have a brown and bown and white on my 94. On the 96 its a red wire and in the book it says that the 94 and 96 have 3 wires, brown, red, brown and white, so WTH
              Try this excel spreadsheet for a 95 to 96 or 97 swap (both are included). I've posted it before. I think it's accurate, but I haven't personally swapped using it.
              Tim
              325 whp 350 lb-ft
                WEll I just got done with installing the wiring harness. It was overall not to bad, but some parts were a little difficult. Now comes the questions
                Will the old cruise control still work with the new computer becasue its on a different wiring harness?
                Do I need to worrie about the Theft system for the OBD II? I know there are a few wires that are not inside my car, casue its a 94 that the 96 has, just need to know if its necessary, if so what do I have to do/get?
                I still have to install the starter motor and the wires for that along with the front knock sensor. I am also going to pick the newer style tranny switch so that it will plug right in.
                  Is there anyway to get around the VATS system? I know the 94 did not come with it, so I was just wondering what would probably happen if the 96 has it and the 94 does not?
                    IM me when you get in. I think I figured it out for you (the passkey stuff).
                    Taylor
                    1998 Lincoln Mark VIII
