Tranny options
  • Tranny options
    I am about to finish my turbo z34 project. I need to know what trannys will fit later on when I blow this one up. how about a 4t65e? Yea or NEA
    getrag 284, mt2, beefed getrag 282 maybe. if you haveor have a skilled welder, you can modify a 4t80e to fit. only 1 bellhousing bolt hole is different iirc. whether or not it will fit into your car...i do not know.
      The 4T65-E it will fit, but running it is a different story.
      The 4T80-E is a different story. It will not fit unless you basically cut the entire front end off of your car and custom mount everything. It is a LOT bigger. And I think that the top 2 bolts will not bolt up (the bellhousing on the 4T80-E is taller for the starter in in the northstars being mounted under the upper intake manifold).
      Not sure about the back bolts, but I think it would be more trouble than it is worth to get the 4T80-E in your car.
      I would stick with the 4T60-E. It is already in there, it can be built up, and you will not have issues with figureing out a computer setup to run it all.
      Taylor
      1998 Lincoln Mark VIII
        See I thought that the 65-e was HD. But what can you do to the 60-e?
          INTERNALLY (under the valve body on the main internals), the 4T60-E and the 4T65- E are almost identical. The only real difference I can think of had to do with the thrust washers. The 60 had like PLASTIC ones, but the 65 had METAL ones.
          A friend of mine rebuilt a 4T60-E using the 65 rebuild kit, and that tranny is STRONG.
          Taylor
            Humm, good to know. I will definitly keep that in mind. Thanks
              The 4T65E-HD can be swapped in and run by a 97 PCM with custom tuning (gear ratio changes and such).
              Tim
              325 whp 350 lb-ft
                So IF a person wants to run a 4T65E-HD WHAT IS NEEDED in a old w-body?
                - Right axle
                - 97+ ECM and harness to the tranny ?
                So in other word a person would have to run your 3.4 DOHC as a "Manual" per-say and Use the 97+ ECM to run the 4T65E-HD as it own stand alone OBD II unit? Correct? Or can the 4T65E-HD be run with the Existing OBD I ECM WITH some mods?
                I want to know the facts cause I want to put the 4T65E-HD in my 3.4 DOHC STE.
                Thanks!
                Regards,
                David
                1991 Grand Prix STE
                3.4 DOHC
                1 of 792 Produced
                Extensive Mods Done
                1991 Lumina Z34
                3.4 DOHC
                Getrag 284 5spd
                1 of 30
                  The 65E can't be run with an old computer. But, they can be run with a couple of the standalone tranny controllers out there, which might be easier than trying to get a stock OBD2 PCM to control it.
