Header Flanges
  • Header Flanges
    We had a batch made up on the cheap, and if anyone is interested in a set as they sit, its the best deal we can offer. $40 shipped for a pair, in the lower 48. 30 a pair for each set after that in the same box.
    3/8" thick mild steel, round 1 5/8" holes, but they were cut so fast that the dimension facing the head is 1 5/8, but the exit side is 1.55". This is perfect for 1.5" primaries or the holes can be straightened out to the 1 5/8". Also, the side facing the head is flat while the side facing away is not so much. It would be a good idea to hit the flat side on a sanding table to be certainly its absolutely flat.
Name:	IMG_20150724_182355 (Medium).jpg
ID:	381616Click image for larger version
Name:	IMG_20150724_182450 (Medium).jpg
ID:	381614Click image for larger version
Name:	IMG_20150724_182443 (Medium).jpg
ID:	381615Click image for larger version
Name:	IMG_20150724_182650 (Medium).jpg
    I was looking for a set of these. Are they on your site?
    Sent from my SCH-I545 using Tapatalk
    "Living is doing everything you want to do and dying is everything else"
      They aren't listed on the store. The custom product listing is the best way to go if you want to go through the store, using a quantity of 40 for 1 set. paypal to sales@wot-tech.com direct also works, with a note that says header flanges ideally. Just make sure the ship to address is accurate in paypal.
