Injector Tester
  • Injector Tester
    Are you going to start offering cleaning services for injectors as well.
      We can handle injector cleaning and testing right now for Multec 1 and 2 along with whatever the 3500/3900 injector style is called. Those are the 3 wiring harness adapters we have currently. This set of trailblazer injectors has been tested on every setting the tester has and flow rates between the injectors has been at most a 2cc spread after 1 minute of operation. This is mostly when the setting is at 7 and above. 5 and below is 1cc.
      Until we get a listing on the store, the custom order function will have to do. $15 an injector cleaned, tested, new O rings and filters. Free shipping in the lower 48, work something out for anywhere else.
        Cool good to know. That clicking in the video is the relay firing the injectors not the injector itself right?
          Look at you getting all high tech. Video looks decently professional, until you get to 9 on the dial, and then it goes to typical Ben...
            i wouldn't be surprised if it were the injectors.... with how fast those things were moving on 9/10(using some rough math and some audio analysis software, I'm seeing ~.012 seconds between clicks, so either around 40 or 80Hz depending on if we're hearing just opening, just closing or both), I don't think a mechanical relay could have kept up. reed relays are quick, but I don't think they would last long at those speeds/currents, I would expect some kind of solid-state driver.
              I made the video for a friend, so its lucky to be nearly professional:P The relays are for the switches and the injector driver is solid state for sure. I bought the unit off ebay and it does IAC and DBW throttle bodies (or did).
                Hey That's a great video
