rebuilding tce adjustable regulator
  • rebuilding tce adjustable regulator
    is there anyway to rebuild it? mine is shot. stays at 20psi unless the screw is screwed pretty much all the way down.
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    I rebuilt my Casper adjustable one by buying a stock fuel pressure regulator and cutting off the top of it. I removed the adjustable top off the bad one by removing the three screws that hold it on. I then drilled the new one for the screws and put the adjustable top on the new one and it worked perfectly. All those TCE AFPR is a machined top on a stock fuel pressure regulator. You should be able to take it apart pretty easily.
    Sent from my Galaxy Nexus using Tapatalk 2
    "Living is doing everything you want to do and dying is everything else"
      i fixed it. i took it apart and found out the pressure plate is a penny. the pressure screw poked a hole through the penny so i replaced it with a quarted instead. problem solved
        Wow its a penny? I can't believe they didn't just machine a plate. That is a good idea though about the quarter. I can't remember how mine was so I might have to pull it apart and look while it's off the car.
          A penny to a quarter? Thats a 2500% Increase in costs! lol
            i think i would have gone with a nickel.
              Now that there is funny....
