Recommended Parts: Performance 3400 Street Built
  • Recommended Parts: Performance 3400 Street Built
    This one is what I would recommend for a performance build that isn't geared solely for budget
    Street/Strip 3500 LX9 Heads
    - Manley Steel Retainers
    Head Bolts
    3400 Competition Upper w/ 65mm TB opening included
    65mm TCE Billet Throttle Body
    3500 Competition Lower
    3500 Metal Head Gasket Kit
    ~$1485 + $420 core ($200 Heads, $80 Upper, $80 Lower, $60 Throttle Body linkage if assembled)
    Optional Upgrades
    +$150 ARP Head Studs
    +$180 Cometic Head Gaskets (.060" thick, any bore)
    +50 8mm Rockers for those with 1996-2001 3400s and some 2002 models with stock 10mm rockers
    Cam Upgrade Package for Performance Street Builds
    Camshaft: MPG, Street, or Street/Strip are ok. Strip recommended
    Custom Length Pushrods
    Completion gasket set (oil pan and timing chain cover stuff
    Wide Cam Bearings
    1994 GM Timing chain, gears, and chain guide
    $687 regular price
    Upgrades
    +$22 Teflon coated cam bearings
    +245 Upgrade GM timing set for TCE Double Roller timing set plus modified crank and modified timing chain cover ($275 core)
      Further recommended upgrades
      #28 Injectors (26.37 @ 55psi on 2000 and newer 3400 engines) $100 while supplies last
      - Adjustable FPR for 1999 and older 3400s $135
      Tuning. Local dyno place is $75 an hour to rent their mustang dyno and the dyno operator is very good with OBD2. Currently no tunes are available off the shelf. For those with OBD1 and swapping in a 3400, the OBD1 tuning service would be worth checking out.
        Bottom End Recommendations
        Stock. Free and if your engine is in good shape already, there is nothing to worry about for a performance street application using the above parts. However, if you want to go further, this is what I recommend.
        Diamond Forged Pistons.
        Sealed Power piston rings
        New Tri Metal Rod and Main Bearings
        Crank Scraper
        $793 Regular price
        Optional Teflon Scraper upgrade +$92
          Looks like you have all the bases covered.
          I love it!
          Very awesome that Diamond is doing 4032 pistons now.....
          We may need to talk some more......
          Matt
            thanks for the thread ben, this will really help.
            this is what i have in mind....anything else i should add?
            3 Piece CAI with K&N
            3500 Metal Head Gasket Kit/Cometic Head Gaskets
            ARP Head Studs
            Street/Strip Camshaft
            Wide Cam Bearings Teflon Coated
            TCE Double Roller
            #28 Injectors
            Adjustable FPR
            Headers
            High-flow cat
            Bigger DP
            2.5" SS mandrel bent piping
            Billet Engine Mount
            Tune
              SS cam might be pretty good for the nitrous but I will have to take do a few simulations. The double roller set is all TCE, nothing GM. The GM 1994 3100 set is its own deal, and is the best you can get without the crank/timing cover work and galley plug grinding for the block. Everything looks good for your build. Nix the head bolts, since you have the head studs listed later.
                Love everything, but need transmission parts now
                Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
