WOT-Tech Cam Dynomation Comparisons.
  • WOT-Tech Cam Dynomation Comparisons.
    It is a pdf file of a stock 3500 engine with the cams that I offer. Since it is a stock motor, the powerband shift is more apparent with the larger cams.
    i can see that MPG cam selling... especially if you don't plan on revving above 6K. makes AT LEAST as much power if not more than the stocker....
      is that whp or power at the crank?
        a stock 3500 doesn't make 200whp Its all at the crank.
          are the gains similar to what a 3400 would expirience?
          MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
