Diamond Piston bore availability
  • Diamond Piston bore availability
    Would it be possible to get Diamond Pistons for the 3400 made .100" over? If so, how much extra $$$?
    '88 Fiero GT - Project MIDTRBO
    '10 Camaro LT/RS
    The rest of my cars are for sale (Click here)
    There's no replacement for turbo placement
    We used to have a chart that showed safe specs for engine bores, and I believe that .060 was the most you want to go and still be in the safe bore wall thickness range in the 60v6 family.
      Under .060 or bust
      Literally.
      Unless you send your block off for hardening, but thats a different story.
      Originally posted by Mars
      Haha ^ Wrong Wheel Drive.
      No 60ºV6 at the moment
        Originally posted by 2.8-350TBI View Post
        Under .060 or bust
        That made me lol.
          The engine would only be about .020 over, I just want .100 over 3400 pistons.
          <<< Not a newb engine builder.
          '10 Camaro LT/RS
            Last I knew, 35.. I mean .100 over 3400 Diamond pistons were not available.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
              3500 block???
                Yep, 3500 block, but 3100/3400 compression height so not 3500 pistons, just 3400 pistons .100 over.
                I know it's a longshot, but if I don't ask then I'll never know.
                '10 Camaro LT/RS
                  That's what I was thinking. Might not even be a GM engine for all we know.
                  EDIT: Ninja'd FTL!
                  This going in your lawn mower in your sig? J/k That pic has always cracked me up, lol.
                    I do ride a Kawasaki Ninja, afterall.
                    Yes it's for the mower, I decided that the 8hp engine just wasn't cutting it.
                    '10 Camaro LT/RS
                      I know its possible and I don't think that bore size will increase costs but I will find out for sure.
                        Before you bore out your cylinders you want to pay for a sonic check to see how far safely you can bore out the cylinders. Every block is different, some 3400's might take .030 more and some might take .050 more. But I see you have a 3500 block and I have no idea how thick the cylinders walls are.
                        I had my 3400 block sonic checked and I safely able to bore it .030 over. Some areas were super thick and other areas weren't.
                        U can see on Cylinder #1 I have a real thin spot and If I bored it .100 over it would be dangerously thin. Good luck with whatever you decide to do.
                        02 GTP - 90* > Failboat
                        www.blackbombshell95.com
                          Great, thanks!
                          Blackbombshell95, that's a good idea, though I'm pretty sure .020" over (.02126" actually) won't be a problem on a 3500 block. The bore is already 2mm larger than a 3400 (94mm vs. 92mm)
                          Thanks for the information on your block, cool to know!
                          '10 Camaro LT/RS
                            They are available and there is no price difference for that bore size.
                              That completely kicks arse, thanks for finding out. I should be ordering some within the year, a lot sooner if the current used shortblock ends up with problems once it's fired.
                              Anyone want to buy a twin-turbo 350 6-speed '90 IROC-Z? It only needs a 'little' (read: a lot) of work! When I'm done with my 60V6 Fiero, my TT V8 won't know what hit it.
                              '10 Camaro LT/RS
