Looking for manifold bolts
  • Looking for manifold bolts
    Looking for the manifold bolts that will work with an Edelbrock lower manifold on a new GM 3.4L crate motor.
    Have you measured the bolt hole/length and went to a joint like Fastenal? I'm not sure if that's the best place but I've replaced certain bolts from their stock.
    I'm not sure what kind of bolt you would need though (not bolt expert heh.) The size would probably be 8-10MM /w 1.25/75mm thread. But a tap/die set has a gap tool but unless you have a bolt that you can test /w it's a tough call. I'd pick up a 8/10mm /w 1.25 thread and see if they thread in; if they do just get enough bolts to bolt it up. Make sure the bolts can handle heat and probably have washer on them maybe? I'm not sure what those are but they should know at fastenal or equal place.
