2 65mm TBs for 3500 plenum, and a 62mm
  • 2 65mm TBs for 3500 plenum, and a 62mm
    TCE found another 62mm they had done before, so I have it back up on the store with 1 in stock.
    I also have 2 65mm TBs that are only good for a 3500 plenum. They come with the adapter special to this particular setup (different O ring setup from the usual TB). $285 shipped.
    Doesnt' come with the blade or the throttle shaft?
      It comes complete with blade and shaft and that adapter in the picture plus 4 bolts for the 3500 plenum. $285 shipped. You can choose the shaft you need from the store (A B C). Save $25 if you modify your own stock shaft and install it yourself with the blade provided.
        damn that is sexy... ill be getting one soon ben... you know i need rods and pistons and cam and pushrods before i can use the tb..lol
          Um, i'd get it now, cause they always sell out. and u will have to wait
          02 GTP - 90* > Failboat
          www.blackbombshell95.com
            dont need the throttle body with out a rotating assembly lol.. rods and pistons are required first
              interested in a 65mm if still available. pm sent.
              -=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
              14.99@91.33mph
                replied. I current have 2 65s and 0 62s now.
                  payment sent
                  14.99@91.33mph
                    any 62s come in?
                      No, they are being made with the 65s.
                        ETA? just got my tax return.
                          Done by the end of next week, in my possession sometime the week after.
                          It would be a good idea to pre order if you want one, especially if you want a 62mm because less of those are made but more can be if need be (first come first serve).
                            I'm not sure if I asked this before, but why a 62mm offered why not just a 65mm only?
                              i think you can only take a 3100/3400 intake to 62 mm safely ?
                              65mm is good for the 3500 intake
