3900 swap from a 3400 want to help?
  • 3900 swap from a 3400 want to help?
    Okay I am trying to figure out how to complete this swap.
    Beginning with a 3.4 v6 from my 99 Grand am SE
    I want to finish with a 3.9 VVT motor from a g6,impala, etc.
    I know you can lock out the phaser to essentially disengage the VVT function.
    And I know about the usual issues with clearance and custom mounts, extending wires and sensors.
    But how do I work around this issue, I need a 24X crank sensor and a single pulse per revolution cam signal. Unfortunately LZ engines do not have a mount for the 24X sensor and their cams have multiple pulses per revolution. Is there any other way around this? I want to keep all my original harnesses and computer modules I don't want to swap all that over if possible.
    Hi!
    I'm wanting to swap an LZ9 and F40 6-speed into my '90 Z24.
    You have some questions about phasers (is this Star Trek?), and 24x this, and such (sorry I'm a bit dated and ignorant of this newer stuff at the moment). Nevertheless, I offer a solution; swap all this newer mech into your older car. Swap all the harnesses from the donor car also.
    I intend to swap all the harnesses I need, from my donor parts car, into my '90 Z24. The car will essentially be a 2006 Pontiac G6 GTP disguised as a Cavy! I know I'm in for a headache, hence my signature
    Let me know how you're progressing and please share any lessons learned from your swap. Best of luck!
    Why do I do this to myself?
