Block
  • Block
    This heavy-duty aluminum block is 47 lbs lighter than a production rear wheel-drive cast iron block. It has extra thick cylinder walls with dry nodular iron sleeves. The head bolt bosses are reinforced to improve head gasket seealing. This block has wider main bearing bulkheads than a production cylinder case; four-bolt caps are installed o­n the two intermediate main bearings. These billet steel main caps have splayed outer bolts that provide additional bearing support.
    The aluminum Bow Tie V6/60 Degree block features a revised lubrication system. The "priority main feed" oiling is similar to a Chevrolet small-block V8, with three oil galleries above the camshaft; production V6/60 blocks have only two oil galleries. Oil is routed directly to the main bearings in a Bow Tie block to ensure proper lubrication at high RPM. The main bearing saddles are grooved to increase the flow of oil to the crankshaft journals through additional feed holes drilled in the upper bearing inserts. Block weight is 59 lbs.
    Technical notes: Aluminum Bow Tie V6/60 engine blocks have rough-bored 89mm cylinders which can be safely overbored to 91mm. Light alloy Bow Tie block have bosses for both FWD and RWD engine mounts. The start motor can be installed on either side of the block.
    Main stud info for all 60 degree V6 engines. (ARP)
    8 - Studs (11mm X 1.5 & 7/16" - 20) - ATP4.65L or Undercut Short studs (11mm x 1.5 & 7/16" - 20) - ATP4.650LU
    8 - Hex Nuts (7/16" - 20) - APN58 or 12 point nuts (7/16" - 20) - APN12-1
    8 - Washers (7/16 ID 13/16 OD) - APW1316N
    i have a question, i have a 2.8 block from a firebird and i aquired a 3.1 crank, pistons, and rods im wondering if they'll fit in the 2.8 block. i was reading up on the two engines and all i see differant is the stroke as far as i can tell, im not sure
      The crank and pistons are necessary, rods are the same as 2.8. Yes, they drop right in.
        does anyone know where i can order the aluminum bowtie block? or even an idea of how much it will cost?
        sigpic<---SERIOUS cornering now
        300NAhp@the wheels....eventually
        http://www.cardomain.com/id/royal455<--new pics of the engine pull on the '94 firebird's page
        http://www.myspace.com/drfeelgood_80
          Free Shipping - Chevrolet Performance 10051141 with qualifying orders of $109. Shop Engines, Bare Blocks at Summit Racing.
          there ya go-$4,000.00 for 50lb less, reinforced headbolt bosses, and extra thick cylinder walls.
