Camshafts
  • Camshafts
    Cam options for the 3.4 DOHC are few and far between. This is the most common reference given for regrinds.
    Steve Long Racing Cams INC.
    951-273-0816
    Cam Timing
    Because the cam gears are not keyed, the options for cam timing are nearly infinite. While this can cause a problem for the novice trying to set the cam timing, it also allows great flexibility for those with more experience. First, I must add that any painted timing marks are to be ignored. To learn more about how to set the cam timing, go here.
    It has been over a year now that the 13 degree exhaust retard spread across the internet as an easy way to get power out of this motor. It seems that another person has experimented with the timing on a ported engine mated to the automatic trans. It retains the 13 degree aspect but advances the intake cam as well to lower the powerband from what we had already tried. I hope this is right, 7 degrees advanced on the intake, 6 degrees retarded o*n the exhaust. As of now I do not know where this lines up the timing mark for 91-93, so you are o*n your own for figuring it out. I do however have a better picture to show the timing mark for the 10 and 13 degree timing. Basically, 10 degrees is what I thought 13 was originally. I am now running 13 on my car but the idle is a hair rougher than with 10.
    Stock Timing
    10 Degree Retard
    13 Degree Retard
    Update: 6-8-05 I have now tried 6 advance intake / 6 retard exhaust on a 94 cutlass and my 91 grand prix. The cutlass is an automatic, and was timed to stock from the belt stretch timing of -8/-8 rear bank, -4/-2 front bank. This obviously made the car idle and run better than before. The 6/6 timing was then applied. Wow...simply amazing for an automatic. The powerband starts lower, idle is smoother than stock timing, and low end is increased a nice amount. Top end was helped out as well over stock though with the auto, stock shift points don't go as high as you can with the manual. The owner also noted an increase in gas milage though I also tuned the chip with this timing done. I am testing the gas milage in my car now.
    6/6 timing on a manual car is a different animal, because instead of shifting at 6200, I usually went to 6600 or so (power dropped after 6600 with 13 degree retard on my motor). My car now only likes to make power to 6200 or so and then drops off noticably. The low end is a hell of a lot nicer and the exhaust note when I cruise around at 1500 is smoother. It no longer feels like its working hard below 2500 I am going to try some more settings out later after I tune my car how it sits and compare gas milage.
    How Exactly Does This Work?
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
      951-273-0816
      Has done three sets of DOHC cams that worked excellent. I can vouch for that! Looking at around 100 a cam.
      3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
      1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
        do you have any video clips of the different settings/cams?
        88 Beretta GT
        69 Corvette
        79 Mustang Ghia
        95 Cutlass Convertible
          No, I never made any videos.
            is rednblack set to this spec now? I assume it would be easier to set this with a cam degree wheel and out of car?
              I might be easier for some to do this out of the car but that is a lot more work just for cam timing. You can PM me if you have a question regarding the car I am selling.
