The 60 degree family tree
  • I'll try and get pics when i go to the Autoshow on Wednesday...
    Cliff Scott
    89 BerettaGT
    89 Volvo740
    Cliff Scott
    89 BerettaGT
    04 AleroGX
    • Sweet thanks. Cant wait till the autoshow comes to vancouver.
      • Ok I'm adding the info on the piston dishes for both the FWD cars and the RWD 3.1L's and 3.4L's. I got alot of info from Colin and found a few specs on the net.
        Anyone know where there is some real numbers? Or does anyone have some pistons free that they can measure them?
        • There's some specs on Silvolite replacement pistons, if that's any help...
          Of course there could be some minor differences though.
          60v6's original Jon M.
          • the silvolite DOHC pistons are the actual pistons used. not sure on the pushrods.
            • Ok what I've go so far is
              All iron heads
              2.8L AL head
              3.1L AL head
              I need the 3100 3400 and 3500 specs for piston dishes.
              Also added the Cumbustion chamber sized for iron and aluminum heads
              • Added this to the site (after a major coding overhaul)....
                • Sweet its UP!. Looks cool. And everyone will be glad to know their name is on the bottom for credit.
                  If you have been missed let Me or Brad know.
                  • The pushrods used Mahle pistons from '87 Gen2 UP
                    Lorenzo
                    • Few things I noticed...
                      Fieros had iron heads through '88 (and were transverse/FWD of course)
                      Not clear on what had iron heads '87-'95 (say FWD iron head ends production in both '87 and '96)
                      Didn't list Gen II head valve sizes
                      if you mention change in something (valve guide sizes in 2000 for instance), mention new sizes and old sizes
                      didn't mention bore of 3.4
                      didn't directly mention stroke of 3.1 or 3.4
                      "close coupled" cats, not "closed coupled" cats
                      only see two references to DIS wheels, thought there were three versions?
                      neutral torque axis engine mount vs torque axis engine mount of early '90's?
                      what's a P05 controller?
                      diameter of pin on large pin 3500 crank?
                      3900 in G6 GTP coming out?
                      earlier, somebody was commenting on the dearth of a-bodies.
                      note the sig... I have an a-body, and it is on track to be pretty fast...
                      Current:
                      \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
                      \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
                      \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
                      Gone, mostly forgotten:
                      \'90 Pontiac 6000 SE AWD: slow but invisible
                      • Just wanted everyone to know that the tree has been updated on the site. The pictures are there, but the links o the larger versions don't work yet. I should get that done in the next day or 2...
                        • F-bodies went serpentine in '87.
                          86 Firebird 2.8 (for now)
                          • '06 3900 has 99 bore by 84 stroke. The bores have been moved outward and are no longer centered over the crank.
                            '06 3500 shares 3900 block, but has 76 mm stroke.
                            Still looking for rod length
                            Current:
                            • That depends on which 3500 you are talking about...
                              The VVT version does share the same block as the 3900, but the standard version has a block still based on the previous 3x00 family.
