FREE CAMSHAFT SELECTION Software from COMP
Similar appearance but I'd stop way short of a watered down version unless your copy of Desktop Dyno makes camshaft recommendations. I have 03 and can enter or choose from a selection of camshafts but the program offers no direct cam selection advice based on my engine specs although it has a general selection. I find the recommendation a lot more favorable than my hypothetical entries particularly when Desktop is probably not accurate enough to trust a hypothetical cam grind developed in it without further input from someone else with appropriate knowledge.
I guess if you look at it more objectively I can see how you can call it watered down though. Just more to the point.Last edited by Guest; 11-25-2009, 02:15 PM.
right, i also have DD03, i play with the Pro Iterator constantly for cam specs. and a couple days ago, i punched in about 200 different real world cam specs. that was an exercise i'll let the iterator do for me. the ability to choose a specific strength, like torque under the curve from 3000-6000 RPM has always shown results that were at least in the right direction, if not entirely accurate. then when you have something like the WOT-Tech cam lobe listing in front of you, it becomes a much simpler game of cat-and-mouse.
