Originally posted by Azrael
View Post
There has been concern about compressor blade damage but it has been proven that as long as the mist contains less than 18 micron droplets there's no problem. This requires the injector nozzle to be placed close to the compressor blades (inches) for a direct path because it prevents the puddling that occurs when a long indirect distance is present allowing for large droplets to develop on inlet plumbing and then hit the compressor blades. It's also less likely to happen in that circumstance when a water/meth mix is used instead of straight water due to a lower specific gravity.
I know they're not exactly the same principle wise but look what it does for the little diesel engines:
and here's a GN user that's in progress:
The most impressive point comes about when you're making a lot of power off a small amount of boost and when you can significantly increase performance on the same amount of boost. We use a lot of old technology standards when addressing performance, but engines built 10-15 yrs ago are not as efficient nor the metals back then as strong as what we have now. We still use the same bsfc numbers in our calculations that were used on those engines and that can't be right given the hp/litre ratios we have now.
Some members on the Fiero forum refer to water injection as a cheap band aid. How redicuolous is that considering the results it produces at such an exceptionally low expense.
