The 3.4 DOHC came with a windage tray, as do the newer pushrod motors. A windage tray helps to keep the oil pan oil seperated from the turbulent oil mist caused from the spinning crankshaft. The 3.4 DOHC tray will drop right in on the gen 2 engines using the parts listed below.
Part numbers:
10162001 - Studs with Extensions for mounting (7 needed)
11517031 - Proper nuts for studs (7 needed)
24503912 - 3400 Windage tray for the 3.4l DOHC
Part numbers:
