3.4L (DOHC) Engine Mechanical Specifications
Application
Millimeters
Inches General Data Engine Type
60° V-6 Displacement
204 Cu In Liter (VIN)
3.4 (X) RPO
LQ1 Bore
92
3.622 Stroke
84
3.307 Deck Height
224
8.818 Compression Ratio
9.50:1 Firing Order
1-2-3-4-5-6 Oil Pressure @ Operating Temperature
103 kPa @ 1100 RPM
15 psi min @ 1100 RPM Cylinder Bore Diameter
92.020-92.038
3.6228-3.6235 Out Of Round Maximum
0.010
0.0004 Taper -- Thrust Side Maximum
0.013
0.00051 Center Distance
111.76
4.4 Piston Diameter-gauged at skirt 10.44 mm
(0.413 in) below centerline of piston pin bore
91.985-92.000
3.6215-3.6220 Clearance
0.020-0.052
0.0008-0.0020 Pin Bore
23.003-23.010
0.9056-0.9059 Piston Ring Compression Groove Clearance 1st and 2nd
0.033-0.079
0.0013-0.0031 Gap (at gauge diameter) 1st
0.20-0.45
0.008-0.018 Gap (at gauge diameter) 2nd
0.56-0.81
0.022-0.032 Oil Groove Clearance
0.028-0.206
0.0011-0.0081 Gap (segment at gauge diameter)
0.25-0.76
0.0098-0.0299 Tension 1st
27.6 N
6.2 lbs Tension 2nd
19.8 N
4.5 lbs Tension Oil
31.2 N
7.0 lbs Piston Pin Diameter
22.9915-22.9964
0.9052-0.9054 Clearance
0.0066-0.0185
0.00026-0.00073 Fit In Rod
0.0165-0.0464
0.0006-0.0018 Crankshaft Main Journal Diameter-All
67.239-67.257
2.6472-2.6479 Taper-Maximum
0.005
0.0002 Out Of Round-Maximum
0.005
0.0002 Cylinder Block Main Bearing Bore Diameter
72.155-72.168
2.8407-2.8412 Crankshaft Main Bearing Inner Diameter
67.289-67.316
2.6492-2.6502 Main Bearing Clearance
0.019-0.064
0.0008-0.0025 Main Thrust Bearing Clearance
0.032-0.077
0.0013-0.0030 Crankshaft End Play
0.06-0.21
0.002-0.008 Crankpin Diameter
50.768-50.784
1.9987-1.9994 Taper-Maximum
0.005
0.005
0.0002 Rod Bearing Bore Diameter
53.962-53.984
2.124-2.125 Rod Inner Bearing Diameter
50.812-50.850
2.000-2.002 Rod Bearing Clearance
0.018-0.062
0.0007-0.0024 Rod Side Clearance
0.18-0.44
0.0071-0.0173 Camshaft Lobe Lift (Intake)
9.398 @ 108° Crank ATDC
0.370 @ 108° Crank ATDC Lobe Lift (Exhaust)
9.389 @ 115° Crank BTDC
0.370 @ 115° Crank BTDC Timing Reference Set Position with Camshaft
Timing Flats in Clamped Position-Right Bank
TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft Timing Reference Set Position with Camshaft
Timing Flats in Clamped Position-Left Bank
TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft Journal Diameter
54.973-55.001
2.1643-2.1654 Bore Inside Diameter
55.050-55.075
2.1673-2.1683 Journal Clearance
0.049-0.102
0.0019-0.0040 Valve System Lifter
Hydraulic Face Angle
45° Seat Angle
46° Seat Runout-Maximum
0.075
0.0030 Seat Width Intake
1.25-1.50
0.0492-0.0591 Exhaust
1.60-1.90
0.063-0.0748 Valve Margin-Minimum
0.75
0.029 Stem Clearance Intake
0.028-0.066
0.0011-0.0026 Stem Clearance Exhaust
0.046-0.084
0.0018-0.0033 Valve Spring Free Length
42.04
1.6551 Load (Closed)-All
289 N @ 35.56
65 lb @ 1.400 Load (Open)-All
711 N @ 26.16
160 lb @ 1.030 Approximate Number of Active Coils
4 Oil Pump Valve to Bore Clearance
0.038-0.089
0.0015-0.0035 Gear Lash
0.094-0.195
0.0037-0.0077 Gear Pocket Depth
30.53-30.61
1.202-1.205 Diameter
38.202-38.252
1.504-1.506 Gear Length
30.45-30.48
1.199-1.20 Diameter
38.05-38.10
1.498-1.50 Side Clearance
0.08-0.10
0.003-0.004 End Clearance
0.05-0.152
0.002-0.006 3.4L (DOHC) Fastener Tightening Specifications
Application
N·m
Lb Ft
Lb In Accelerator Control Cable Bracket Bolt
10
89 Accelerator Control Cable Bracket Nut
10
89 Camshaft Carrier Cover Bolt
11
97 Camshaft Carrier Thrust Plate Bolt
10
89 Camshaft Carrier Thrust Plate Cover Bolt
10
89 Camshaft Drive Belt Cover Bolt
10
89 Camshaft Drive Sprocket Bolt
130
96
-- Camshaft Housing Assembly Bolt
27
20
-- Camshaft Position Sensor Bolt
50
37
-- Connecting Rod Cap Nut
20 +75°
15 +75°
-- Coolant By-Pass Nut
25
18
-- Coolant Inlet Housing Bolt
25
18
-- Coolant Outlet Bolt
27
20
-- Coolant Pump Bolt
11
97 Coolant Pump Pulley Bolt
25
18
-- Crankshaft Balancer Mounting Bolt
107
79
-- Crankshaft Main Bearing Cap Bolt
50+75°
37+75°
-- Crankshaft Main Bearing Cap Stud
50+75°
37+75°
-- Crankshaft Oil Deflector Nut
25
18
-- Crankshaft Pulley-to-Crankshaft Damper Bolt
60
44
-- Crankshaft Position Sensor Bolt-Front of
Engine
8
71 Crankshaft Position Sensor Bolt-Side of Engine
8
71 Crankshaft Position Sensor Harness Retaining
Bracket Bolt
5
45 Cylinder Head Bolt
60 +90°
44 +90°
-- Drive Belt Tensioner Bolt
50
37
-- EGR Valve Adapter Brace Nut
25
18
-- EGR Valve Adapter Stud
10
89 EGR Tube Assembly
25
18
-- EGR Valve Assembly Nut
25
18
-- Electronic Ignition Control Module Assemble
Bolt/Stud
25
18
-- Electronic Ignition Control Assembly Nut
25
18
-- Engine Block Coolant Drain Plug
19
14
-- Engine Block Oil Gallery Plug-Center Rear
16
12
-- Engine Block Oil Gallery Plug-Rear
33
24
-- Engine Block Oil Gallery Plug-Side of Block
19
14
-- Engine Coolant Temperature Sensor
18
13
-- Engine Motor Mount Frame Nut-Engine Left Side
43
32
-- Engine Motor Mount Bracket Nut-Engine Left
Side
43
32
-- Engine Motor Mount Frame Nut-Engine Right Side
43
32
-- Engine Motor Mount Bracket Nut-Engine Right
Side
47
35
-- Engine Motor Mount Bracket -Front of Block
Bolt-Engine Left Side
103
76
-- Engine Motor Mount Bracket-Side of Block
Bolts-Engine Left Side
58
43
-- Engine Motor Mount Bracket-Front of Block
Bolts-Engine Right Side
102
75
Bolt-Engine Right Side
58
43
-- Engine Motor Mount Bracket-Transaxle
75
55
-- Engine Mount Strut Bracket Bolt
80
59
-- Engine Oil Cooler Connector
40
30
-- Engine Oil Level Sensor
22
16
-- Evaporator Emission Canister Purge Solenoid
Mounting Bracket Bolt
10
89 Exhaust Manifold Crossover Stud
9
80 Exhaust Manifold Nut
13
116 Exhaust Manifold Stud
17
13
-- Flywheel Bolt
82
60
-- Front Cover Coolant Drain Plug
25
18
-- Front Cover Bolts- Large
47
35
-- Front Cover Bolts - Small
27
20
-- Front Cover-to-Front Engine Lift Hook Bolt
25
18
-- Front Engine Lift Hook-to-Right Camshaft
Carrier Bolt
50
37
-- Front Engine Lift Hook-to-Right Cylinder Head
Bolt (Access through Front Cover)
50
37
-- Fuel Pipe Clip Bolt
7
62 Fuel Pipe Retainer Screw
3
27 Fuel Rail Assembly Bolt
10
89 Ignition Coil Bolt
25
18
-- Ignition Coil Nut
25
18
-- Intermediate Drive Shaft Retainer Screw
10
89 Intermediate Shaft Belt Sprocket Bolt
130
96
-- Knock Sensor
21
15
-- Lower Intake Manifold Mounting Bolt
13
116 Manifold Absolute Pressure Sensor Bracket Bolt
8
71 Oil Cooler Connector
40
30
-- Oil Cooler Hose Fitting
25
18
-- Oil Distribution Cover Bolt
27
20
-- Oil Filter
16
12
-- Oil Filter Fitting
67
49
-- Oil Level Indicator Bolt
10
89 Oil Pan Bolt-Except Rear
11
97 Oil Pan Bolt-Rear (2)
27
20
-- Oil Pan Drain Plug
25
18
-- Oil Pan Nut
11
97 Oil Pan Stud-to-Cylinder Block
10
89 Oil Pressure Switch
32
24
-- Oil Pump Cover Bolt
10
89 Oil Pump Drive Clamp Bolt
36
27
-- Oil Pump-to-Rear Main Cap Bolt
54
40
-- Power Brake Booster Vacuum Pipe Fitting
18
13
-- Rear Engine Mount Strut Bracket Bolt
82
60
-- Secondary Air Injection Pipe
25
18
-- Secondary Air Injection Pipe Nut-Left Side
25
18
-- Secondary Air Injection Pipe Support Bolt
10
89 Secondary Air Injection Pipe Nut-Right Side
10
89 Serpentine Drive belt tensioner bolt
50
37
-- Spark Plug
20
15
-- Throttle Body Adapter Bolt
25
18
-- Throttle Body Adapter Nut
25
18
-- Throttle Body Heater Outlet Hose Nipple
18
13
-- Throttle Body Stud
4
36 Throttle Body Bolt
10
89 Tie Bar Bracket
26
19
-- Timing Belt Cover Bolt
10
89 Timing Belt Idler Pulley Bolt
50
37
-- Timing Belt Tensioner Actuator Bracket Bolt
50
37
-- Timing Belt Tensioner Actuator Pulley Pivot
Bolt
50
37
-- Timing Belt Tenisoner Actuator Side Plate Bolt
27
20
-- Timing Chain Tensioner Bolt
27
20
-- Engine Mount Strut and Engine Lift Bracket
Bolt
70
52
-- Upper Intake Manifold Retaining Bolt
26
19
-- Water Inlet Fitting to Front Cover
27
20
-- Vacuum Source Manifold Mounting Bolt
7
62
Application
Millimeters
3.4 (X) RPO
LQ1 Bore
92
3.622 Stroke
84
3.307 Deck Height
224
9.50:1 Firing Order
103 kPa @ 1100 RPM
92.020-92.038
0.010
0.013
111.76
91.985-92.000
0.020-0.052
23.003-23.010
0.033-0.079
0.20-0.45
0.56-0.81
0.028-0.206
0.25-0.76
27.6 N
6.2 lbs Tension 2nd
19.8 N
4.5 lbs Tension Oil
31.2 N
22.9915-22.9964
0.0066-0.0185
0.0165-0.0464
67.239-67.257
0.005
0.005
72.155-72.168
67.289-67.316
0.019-0.064
0.032-0.077
0.06-0.21
50.768-50.784
0.005
0.005
53.962-53.984
50.812-50.850
0.018-0.062
0.18-0.44
54.973-55.001
55.050-55.075
0.049-0.102
45° Seat Angle
0.075
1.25-1.50
1.60-1.90
0.75
0.028-0.066
0.046-0.084
42.04
289 N @ 35.56
711 N @ 26.16
0.038-0.089
0.094-0.195
30.53-30.61
38.202-38.252
30.45-30.48
1.199-1.20 Diameter
38.05-38.10
0.08-0.10
0.05-0.152
Application
N·m
Lb Ft
10
10
11
10
10
10
130
96
27
20
50
37
20 +75°
15 +75°
25
18
25
18
27
20
11
25
18
107
79
50+75°
37+75°
50+75°
37+75°
25
18
60
44
Engine
8
8
Bracket Bolt
5
60 +90°
44 +90°
50
37
25
18
10
25
18
25
18
Bolt/Stud
25
18
25
18
19
14
16
12
33
24
19
14
18
13
43
32
Side
43
32
43
32
Side
47
35
103
76
58
43
102
75
58
43
75
55
80
59
40
30
22
16
10
9
13
17
13
-- Flywheel Bolt
82
60
25
18
47
35
27
20
25
18
Carrier Bolt
50
37
50
37
7
3
10
25
18
25
18
10
130
96
-- Knock Sensor
21
15
13
8
40
30
25
18
27
20
-- Oil Filter
16
12
67
49
10
11
27
20
25
18
-- Oil Pan Nut
11
10
32
24
10
36
27
54
40
18
13
82
60
25
18
25
18
10
10
50
37
-- Spark Plug
20
15
25
18
25
18
18
13
4
10
89 Tie Bar Bracket
26
19
10
50
37
50
37
Bolt
50
37
27
20
27
20
Bolt
70
52
26
19
27
20
7
62
