Originally posted by RedBird
View Post
swapped 3500 heads
that's true. it's funny that i've been thinking about the pushrod thing all day but didn't mention it. LOL, trade the mount hassle for pushrod hassles. in that case the 3400 does sound that much better, doesn't itoh well.
there's an idea for the store..... Hybrid Pushrods
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
The problem with the pushrods is the fact that each hybrid is different. There is the hybrid with the stock cam or a myriad of aftermarket cams. Each one would need a different size pushrod. There have been several discussions on this over the years, so maybe we should just compile the list of different lengths and incorporate it into one of the site articles. Since there are also a bunch of different companies that can do custom pushrods, once a person has the correct info, they can just order it. It wouldn't be profitable for Ben to carry them because he would have to stock all the different variances in order to get a decent price and would most likely end up with a ton of extras because it honestly isn't going to be something alot of people are going to buy.-Brad-
I am sure it's a fidanza flywheel.
The 272 may be able to use the stock pushrods, but who says they are the ideal length? So sure, a "generic" length could be made, but then Ben would just be selling mediocore parts...-Brad-
my flywheel is a fidanza... i bought it off of ebay...1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Originally posted by bszopi View PostThe 272 may be able to use the stock pushrods, but who says they are the ideal length? So sure, a "generic" length could be made, but then Ben would just be selling mediocore parts...Lifting my front wheels, one jack at a time.
But again, in order to make it worth it for Ben to buy them, he'd have to buy a large quantity, and then still sell them equal to or higher than other places. So it wouldn't be worth it to him. Find out the right length (its been discussed on here before, and its most likely on domesticcrew as well), then order it from one of the online stores.-Brad-
My whole goal is to do something others are not doing and to see how much power I can pull out of this engine combo.
So my question again to those that might know, what are the major issues if I use these on my 3.1L Block instead of going with the 3400 heads? on a hybrid V6/60.I dont know what this means but "ASS HATS" is funny
i dont see any real problems from any other hybrid. you'd have to drill the block for the LIM to block gaskets just liek putting 3500 heads and intakes on a 3400. i haven't looked much at 3500's, so i dont know a lot about the coolant lines and such......
Cammed 3500 --> ???
Its all the same between 3100 and 3400. I think the 3100 bore is right on the edge of the combustion chamber so if thats true its fine. I don't have a 3100 gasket here to compare with though, just the bore measurement.
As for the pushrods, each application has potential to be different. MMS sells stocklength which is pretty pointless. Even if I sold a set that matched 1 setup, it might be .010 off from someone else using a different cam or shaved heads or decked block. You should really do the measurements yourself and have them custom made. Crane isn't very good for tolerances though. I can try to find a place to make us a quality custom length pushrod on a per order bases.Ben
if you did that that'd be nifty but if crane isn't too great can you just recommend a place that makes good quality pushrods? I *am* going to need a set in the not-too-far-off future.....
Cammed 3500 --> ???
