heres alittle info i have from just finishing the 3500 head swap...
first of all the 3500 heads are NICE.. the combustion chamber is compareably smaller than the 3400 heads.. i cc'ed the 3500 heads and got 30.5cc if i remember correctly so its pushing 10 to 1 compression.. i used the 3400 head gaskets.. the 3500 heads requires use of the 3500 lower intake manifold and lower intake manifold gaskets.. i opted to use the lower intake manifold gaskets that go between the block and the lower intake seeing as the gap was way to big to fill with rtv like on the 3400.. the pushrod lengths on both 3400 and 3500 are the same.. i also tested the valve springs on the 3500 heads which turned out to be stronger than the ls1 springs..the 3500 lower intake manifold has no ect hole so you have to drill and tap that.. i used a 9/16" bit and a 3/8 npt tap to get that job done.. i also had to tap the heater hose hole with a 1/2 npt for my application.
heads with almost no miles cost me 265bucks
new head bolts 5bucks each need 16 bolts
lower intake manifold new from gm 136.10bucks
head gaskets 55 for both
lower intake manifold gaskets 35bucks
upper intake manifold gaskets 30bucks
exhaust manifold gaskets 22bucks
drill bit 20 bucks
3/8 npt tap 8bucks
1/2 npt 20 bucks (used it for alot of stuff.)
total cost of swap was about 680 bucks...
drill bit 20 bucks
3/8 npt tap 8bucks
