I have a '90 TSTE that the came went out on.. ate lobe 9 entirely. I'm installing an oiler setup in the midst of my rebuild to keep this from ever happening again. My problem now is finding a fitting to use on the end of the pipe to spray the lobes down with, without spraying too much volume or accidently starving the rest of the motor.
I was looking at these:
Mainly at the "spray fittings." I'm more or less just asking for recommendations on CFM ratings.
.JPG)
thank you
thank you
