The MAF will put a signal out...the problem is the max MAF limit for this context 11.5kHz is "HARDWIRED" into the PCM. So unless you are smarter than GM the only thing you can do is 'lie' to the PCM...whatever the implication there...sooner or later (well I guess it depends what the application is) you loose resolution and granularity..."garbage in garbage out"...
Also without testing or mathematically eliminating the turbine wheel as a restriction you cannot just say it has become one...what exhaust are you running and what are the cam specs!?!?
