i'm in the middle of building a 3.1 RWD for a prodject car i'm shooting for somthing close to 300HP heres what i have so far tel me what you think.
3.1 lowerend stock with arp bolts and shot peened polished rods
3.5 Heads
3.5 LIM
custom Upper intake made to mount 2 44mm sidedrafts
cam from crower or lunuti with redline set at 7000rpm peak at around 6500
custom long tube headers with primarys around 28-32"
electromtive HPX or XPI DIS ignition
and a lightweight flywheel like 8-12lbs
the engine will only have to run the alt and water pump, and will be mounted to in custom built car i will be porting the heads and intake a little to clean up the castings and gasket match so tell me what you all think.
3.5 Heads
3.5 LIM
