I'm needin to get a little better response from my beast, especially at cruising speeds. The 3400's always seem to be sluggish on the gettin-goin, but pull great once she's strokin down the road.
Anyways, I've concluded that my bored 60mm stock TB has got to go, I'm lookin into the 65mm unit, and possibly larger - but the hp budget is kinda tight right now. Any suggestions for a cheap, larger bore unit?
Secondly, the friggn heat we've had here is killer, and for some reason when it's anything over 80* outside, the motor is just really sluggish. I'm thinking of moving the air filter intake to the pass side fenderwell and running a long intake tube from the pass side to the drivers side in front of the condenser, and then back up and into the engine bay (as the CAI setups for the GA's), but not really sure if this is worth the hassel. I think having that long of a straight tube for the intake could really help speed up the high end air flow, but prob just wishful thinking
Any opinions?
And thirdly, has anyone installed a high flow pump into the newer fuel pump assemblies and had problems with fuel pickup when the tank starts getting low? When it's down to about a 1/4 full, the car will damn near stall out from lack of fuel to the pump when you lay into it and everything sloshes to the back of the tank. I'm trying to come up with some kinda fuel pickup that can run from the bottom of the assembly to near the back of the tank, but with the unit installed there's only about 1/4" of space between the bottom of the assembly and the tank. Any suggestions?
