Here are some shots of the timing chain cover from the 3900 compared to the Gen3 cover. As you can see the center is raised quite a bit to clear the VVT unit, the water pump has been relocated, the 3 bolts that are used for motor mounts on some engines has been reduced from M12 to M8, 2 other bolts were changed from M10 to M8 and the water passages have been rerouted around front of cover instead of over the top.
Top view of new vs. old
Side view of new cover
Red dots show the M12 holes that changed to M8
