Fuel Pump Upgrade?
  • Fuel Pump Upgrade?
    I want to add a fuel pump upgrade to V6/60 while I am going boosted and N20.
    What are your opinions on this pump from MSD?
    I am looking at the numbers and I dont think it will be good enough. Or maybe I am just trying for overkill.
    Tell me what you think. Even give me a few suggestions.
    I dont know what this means but "ASS HATS" is funny
    Maybe if you are going with a fuel cell. Otherwise, you have an in-tank pump, correct?
    Regards,
    Todd E. Johnson
      I bet ya do
      As far as in-tank pumps go, this is your best bet:
      in-tank pump
      she requires a little bit of wire swapping and splicing, but works great. Installation in the OBDII pump assembly vehicles is a bit tricky, but it can be done with some careful work. Price ain't all that bad compared to other internal / external pumps on the market, either.
      pump flow is rated 67gph with max psi rating of 90.
      this pump is a direct replacement for anyone with a late 80's early 90's F-body, too - harness and all
      N-body enthusiast:
      {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
      {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
      Current Project:
      {'90 Chevrolet C1500 Sport 350TBI}
        Depending on the vehicle you have, it may have a line coming off the pump to a venturi pump in the bottom of the fuel assembly. If you don't supply that line with pressure, you will have issues. I think I remember you had a 3100, but I can't for the life of me remember what vehicle you have...
        Regards,
        Todd E. Johnson
          My car is a cavalier.
          engine is being built.
          3.1L Block
          3400 heads
          3.5L Intake
          4.3L TB
          hypereutectic .40 over Pistons
          hayes rings and Bearings
          High Vol/Pres Oil Pump
          CraneCam 272
          Comp Cams LS6 Valve Springs
          Comp Cams Roller Rockers 1.6 Ratio
          Comp Lifters
          Comp Cams retainers and locks
          MSD DIS-4
          MSD DIS Interface Blocks
          MSD Coils
          MSD Wires
          NGK Iridium Plugs 2 ranges colder
          19# Accel Injectors
          T4 Garret Turbo
          Venom N20 System 125HP w/
          Heater, Blow Down Tube, remote Opener
          I hope this gives you an idea of what I have in mind. So you can see I need more FUEL.
            The walbro intake pump is also a good choice. Flows 255lph (or 67gph so about the same).
            '97 Grand Prix GT 3800 (sold)
            Gotta love boost!
              3.1L Block
              3400 heads
              3.5L Intake
              4.3L TB
              CraneCam 272
              Comp Lifters
              MSD DIS-4
              MSD Coils
              MSD Wires
              19# Accel Injectors
              T4 Garret Turbo
              That's cool, but not why I asked... lol I want to know what exact body style and year of the car for more info on the gas tank and fuel pump assembly
              Because.... If the pump assembly has a venturi, then you should get the 3800 specific walbro kit from ZZP, otherwise, any other in-tank pump with 12ga line will work
              Regards,
              Todd E. Johnson
                I have two tanks.
                A 1992 and A 1994
                  D'oh! Too old for my service manual. Have you pulled the fuel addambly outta them yet? If so, is there a plastic line going from the pump to the bottom of the assembly?
                  Regards,
                  Todd E. Johnson
                    Nope have yet to pull the sending units.
                    I will do it this week.
                      Feul pump upgrade, no stock unit, fuel cell usage
                      I'm looking for suggestions for my 3.5l that will be SC in the next year or two. My car will have a fuel cell so we are talking an external fuel pump. Will the one listed earlier in the thread be a good one to begin looking at?
                      Any other suggestions?
                      in build, Stage 1
                      1976 MGB - 3.5l (2004 Malibu), GM V8 T5, 3.9 gear
                      FAST ecm
                        Todd.....did you ever get that monster running ?....your GroomLake photos hvnt been updated in a while.
