Today I looked over the lifter valley and noticed the ridges that direct oil over the lobes on the camshaft. Upon closer inspection I noticed the casting not so perfect (who would have thunk). Some of the ridges are very close to the edge of the cam lobes and I wonder how well these oil directors function... do you think I should file the block a tad so the oil doesnt overshoot the lobes as it spills down onto the cam? i wonder if anyone has tested the pathways for oil accuracy.
It might just be something for the future as my block has already been rebuilt and the last thing i want is filings in my engine.
on another note... upon trying to install my arp head studs I found they would thread about 1/4" down, or about 4 threads then bind.. I examined the stock headbolts to find they are 10m 1.5m, and they have a lot of play in them, strange.... so I went to greggs and bought a 11m 1.5m tap (as the head studs are 11m) and retapped the block... the tap went in easy , a little tighter at the bottem, and only minimal material was removed, but my head studs go in the block as easy as they would a woman with 5 children.
Now for my question.. ARP gives 3 torquing tables that are sectioned under different tensile loads. but it says they are all generalized and not necessarily engine specific... what happens if I tighten the head studs down more than spec'd in the haynes manual?
