I changed out my TCC sensor in my tranny and the dang thing still gets stuck open. i cant seem to get it fixed. I dont know what else I can do to fix it. Have any of you other guys had this problem.
TCC Sensor (again)
I'm not sure you ever mentioned the year of GA you have, but the attached should help. If I remember right, RSM also jacks up the shift pressure to stupid levels. That, and no MAF, well...
I'd be surprised you don't have things lodged in your valve body...Attached Files
Originally posted by tejohnsonI'm not sure you ever mentioned the year of GA you have, but the attached should help. If I remember right, RSM also jacks up the shift pressure to stupid levels. That, and no MAF, well...
I'd be surprised you don't have things lodged in your valve body...Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
Ouch!! Maybe the computer won't engange the TCC since the MAF is off either... Would make sense.sigpicNew 2010 project (click image)
Originally posted by john_V63400Actaully, If you read the post you would know I did change it out, and the problem persist. I think Ill listen to tj and GTR ince it all adds up to what problems Ive been having. Thanks guys. Appreciate it.
I had that problem in my TH125C, and it was just a matter of unjamming the tcc valve and everything worked ok after that.
~Rob
-=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
14.99@91.33mph
Originally posted by barrok69I read your post and it said you replaced your sensor, i'm guessing you meant solenoid. I wasn't referring to your sensor/solenoid. Theres and actual valve that the solenoid pushes to engage the TCC. If the valve is stuck or jammed then u can put as many new solenoids in as you want, but your TCC still won't engage until you fix the valve. Now i'm not saying THIs is your problem but its another thing to look at.
~Rob
Which is why I said "I'd be surprised you don't have things lodged in your valve body..."
If you have a way to scan and edit the PCM, then scan the TAPS values and look for wild variations. That may give hints about the hydraulic components condition.Last edited by tejohnson; 07-01-2006, 07:57 PM.
