I recently bought a Granatelli MAF w/ cold air tuning for my '99 GA 3400; I installed it per their instructions (disconnect both + and - batt terminals), fired it up and let the computer re-learn its idle. Well, after letting the motor run for about 45 minutes, I drove it around a bit (every time I can to a stop, the motor would surge for a coupla seconds until it finally evened out, also bogged down something terrible when I'd go WOT), came back home and cut it off. I couldn't get it to restart unless the motor cooled for about 30 minutes. Odd. Never kicked a DTC (no pending, either). Put the factory MAF back in and the motor runs fine again . . .
Anyways, I'm also running a DHP 1.0 PCM. I called customer service at Granatelli and they said there's nothing wrong with their unit (based upon the same description that I gave them), and DHP states something along the lines of if I'm not pulling enough air to justify the MAF, then I really don't need it (or something to that effect). Currently, my motor is mostly stock, 60mm TB, CAI, plenum spacers (I thought I was running my ported manifolds, but realized Sat they're still sittin in the motor room at the shop
Anyone else have this type of problem with a Granatelli MAF w/ a DHP PCM? Just curious for some thoughts 'fore I box it back up and send it out . . .
