Everything looks good. Size of the timing wheel does not matter at all. Wether it is larger or smaller the same amount of slots will pass by the sensor on every RPM. So no need to worry about that. Just be sure they are the same spread as the stock reluctor.
My only concern is that you are going to be machining the outer dampner ring for your trigger. The only concern would be if the ring shifts on the center hub because of the rubber isolator. Now on the FWD cars the dampner is designed to turn a belt so I think that it is locked in place and you shouldn't have a problem. But what you may want to consider is a reluctor that bolts to the center hubs 3 bolt holes
The way I made my trigger ring was to weld a ring to the back side or a RWD pully. This was also good because you could do a belt change and still leave the ring and sensor in tact.
Just for anyones refrence the stock PCM will allow about 10* difference before it sets a code. When it does you will be running on default fuel and timing tables and will burn ALOT of gas.
