I was wondering something, lots of people get their heads decked, either for more power through the higher compression ratio or just to ensure their flat (or both). Well it seems that if you deck them making them a tad bit shorter, all of a sudden the LIM and exhaust mani's woulden't align correctly?
Decking Head Question
SpudFiles
Theopia
Enjoy life online.
3500 swap, 60degreeV6 1393 Cam, Ported Intakes, Comp Cams Valve Springs, 65mm TB, Custom Pushrods, S&S Headers, 97 PCM with DHP Powrtuner, 2.5" back to dual Hooker Aerochambers, SS Brake Lines, Addco swaybar, KYB's, Intrax Springs, STB's, etc!Tags: None
Intake can be a problem if you take too much off. But usually if only enough it remove to clean up the head your fine. But if it comes down to it the machine shop will also need to machine the intake.
The exhaust manifolds are usually not a problem at all since there is plenty of play in the exhaust and the flex joint on the rear manifold.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Is it worth it to have them decked as much as I can for a higher CR then deck the lower intake or just leave it?SpudFiles
Theopia
Enjoy life online.
I had mine deck .020 and never ran into an issue with anything lining up.2006 G6 GTP MT6
Vector Motorsports ECU
Classic Performance 2.5 Inch Exhaust
v6h.o. Downpipe
Custom Intake
Does the extra compression help at all? Could decking .020 bring me to 10:1 or higher?
The way I figure is if i'm going to have them decked to be level then I should just have them decked for best performance.SpudFiles
Theopia
Enjoy life online.
Yeah if I had more money I couldSpudFiles
Theopia
Enjoy life online.
Anyone with some of those uber engine specs at the top of their head care to tell me if decking .020 is safe (still enough clearence for the pistons at high RPM's, etc).SpudFiles
Theopia
Enjoy life online.
Don't be under the impression that compression will make power. Go to crazy and you will run into detonation problems or early pinging which will retard ignition timing. Be aware of the fuel you choose to run, your cam specs, ignition timing and ECM programming. If you want to tear your motor down and run a cam optimized for more compressiona nd hten have hte ECM tuned accordingly then go ahead and have the compression increased into the high 10's or so. Otherwise clean up the heads and bolt everything back on and you will be better off.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
