May 20, 2006 - went to Palm Springs for West Coast F-Bodies dyno day. Temperature SUCKED @ 101* w/ 11% humidity. Ugh. Felt like i was in an oven.
Anyhow, car got up on the dyno, first one up, the tuning guy made the two runs using a wideband sensor.
For those of you that aren't reading the graphic, thats 184.32 RWHP @ around 4800 rpm, and 212 RWTQ @ around 4100 rpm (216 bhp/250 btq for those of you following). Apparently the cam has pushed the powerband of the car up a bit. (that was with the cutout fully open).
The silver lining to the cloud: I have a 216 hp / 250 tq 3.4L Camaro. That's well above the stock 160 hp / 200 tq that comes from the factory. I'll have to hit the track and see what kind of times I can get with this setup. I also really really wanna tune the car.
I was kind of disheartened by this dyno as I was expecting better results, however the guy that tunes cars (mostly v8 F-Bodies and the new GTOs) took me aside and pointed out the really bad 10:1 AFR and even the not-so-good 12:1 AFR at the end. He told me that if I could lean out the mix / tune the car, i would see a 10-15 tq gain down low, and then he chimed in with, "and you have a driveshaft problem you need to fix that's costing you hp/tq up top."
Those of you that have been following my posts around the boards know that I've had a mysterious vibration in the driveline and, long story short, have replaced the carrier, carrier bearings, rebalanced the tires, reshimmed the carrier and wondered about having the pinion bearings replaced...
Anyway, I have some work to do... Changed the plugs to Bosch Platinum+4, we'll see if those help any. Lots of thinking to do. Megasquirt is in my future...
