Block Question
  • Block Question
    Gotta question:
    Will a 3.1MPFI block fit on a 2000 model 3100?
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    just the block? you'll run into the same problems as those swapping from a 3.1 to a 3x00. bosses are different for the front mount. you'll also run into problems using the 3x00 main caps and oil pan.
      Doesn't the 3100 also have a cam sensor? where as the 3.1's dont?
      1999 Grand Prix SE 3100
      1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
      1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
        yes it does. motor would still run without it but throw a code and emmisions guys love that.
          it won't run nicely with out the cam sensor. It affects fueling and will rough bad at certain points.
            Alright. Thanks guys.
            Just asking for a friend who needs a new 3100 block.
            1995 Grand Am GT
            www.3400swap.com
              Tell him to make sure ge gets a 3100 block. They are alot better in many respects. The best being priority main feed oiling and then the roller lifters.
                Will do. Thanks.
                1995 Grand Am GT
                www.3400swap.com
