3.1 to 3400 top end swap ????
  • 3.1 to 3400 top end swap ????
    i am thinking of doing this swap what kind of gains are you guys getting with this swap any dynoed results would be great or any other info on this matter would be helpful
    Is your motor a 3.1mpfi? Or a 94+ 3100?
    Rough guess is with a 3.1L displacement and the 3400 heads/intakes you'd be at the new style 2000+ 3100. So ~170-175hp. Of course it could be less since the computer may not be optimally tuned, or it could be more if you have exhaust work done/etc.
      wow if its possible to get 180 out of these cars with just some exhaust work, 3400 heads, and tuning, ive gotta try this ou (once my car is running again, that is...lol). good luck man.
        Well, if you look at the stock 3100/3400 numbers, and then you change the top end, the only difference from a stock 3100 is the bottom end, and if you are displacing the same, a good tune should produce the stock numbers.
        I'm guessing here, but if you had a 3400, add cam, UDP, headers, exhaust, CAI, 3500 plenum (or 3500 whole top end; heads up), maybe a little more compression, 65mm TB, and a good tune so it runs optimally, you could see 240hp at the crank, maybe more... Don't forget a correct port and polish.. Remember I'm just guessing, but I believe it to be possible.
          i did the hybrid swap but added a heavy cam, i am now just getting it to run right should be taken it for a spin this weekend.
          but i am hopen for around at least 200whp
          all stock a hybrid is suppose to be in the 14's
            If you're motor is making 240hp, and you have a manual, you probably are putting 200 to the ground.
            Syn, did you use a 3500 plenum? I can't remember. Anywho was the injector o-ring hole vacuum leak the only problem? Or was a coil or two bad?
              no i opted for the 3400 as money was a issue as time was. the only probs i have now is idleing at closed loop it won't idle at all. its almost like its in limp mode
                Get some datalogs of that thing
                  my lab top only has a serial port, and i've heard i need a usb so can i or not use a serial port aldl cable? anyone know where the cheapest place to get one is?
                      i was watching that but wasn't sure if thats what i needed
                      thanks
                        why does everyone call them lab tops? it's a laP top... cause it fits in your lap... i personally have a lab at work and in my lab i have 4 desktop computers...
                          haha i never noticed
                          i use to call curbs curves too
                            Damn, I'm mesmerized by your avatar....
                              ok i got a ALDL cable ordered it sunday noight should be here hoprfully by friday so i can get some data logs finally
