AC delete pulley
  • AC delete pulley
    Does anyone make a pulley setup to delete the AC compressor for the W-body cars? I know they make them for the f-bodys.
    Or is there a simple solution that I dont know about.
    thanks for any advice.
    1999 Grand Prix SE 3100
    1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
    1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
    That should work.
      Originally posted by sappyse107
      http://www.midwayautosupply.com/detailedproductdescription.asp?13077
      That should work.
      Ah, Thanks
      That should free up a little more HP.
        Not likely, since the AC doesn't run at WOT and its just an idler pulley in that state anyway. It will free up some space and reduce a little weight but its not worth doing for performance reasons alone.
          mine was about $23 from the GM dealership. i ordered it for an '88 Corisca 2.8 with no AC IIRC.
          '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
          '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
          GM W-body Forums
            Do these for the 2.8/3.1 fit the 3100/3400? I've never gotten a clear answer on that... some say yes, some say no...
              it also needs a special bolt, i used a chunk of pipe and made a bushing/spacer to take care of that and used a hardware store bolt.
                mine came with the bolt. i just took it out of the box and bolted it on.
                GM W-body Forums
                  Would you by chance happen to have the part#?
                    uh it's in the first pic. #10044867
                    GM W-body Forums
                      opps! I'm an idiot. I looked at the picture.
                        I take it this bolts to the 3100/3400. It looks like it's on one in the pictures..
                          i'm not sure if it would work on the 3100/3400 or not yet. the pics above are of my turbo'd '91 3.1
                          GM W-body Forums
                            Looked like a low mileage 3400 b/c it was so new looking. That's one clean motor you got there!!! The timing cover looks brand new!
                              heres my a/c delete autozone helped alot on this one
                              i used washers to get the correct spaceing as i didn't have the thing on my timing cover for a idler pulley
