i have found a 2001 LG8 3100 engine in the local salvage yard. the engine is bad (not sure how yet) and is already out of the car. i can get everything from the heads up for $150.
i'm not at all familiar with GEN-III stuff (yet). i was wanting to get the heads/intake/plenum off the 3100 and use it on my Turbo STE's LG5.
- what modifications will need to be done to the valvetrain to make this work? what lifters, pushrods, and rocker arms should be used?
- what would the CR be on a GEN-II engine with GEN-III topend?
- would it be a better idea to just get the entire 3100 and rebuild it? and if so is 3100's 9.6:1 CR too high for 10-12psi?
i'm planning on using a GT3071R-WG turbo and would really like to upgrade the intake beforehand. i will be using TGP wiring harness and ECM/memal and a Getrag 282. i know i'll have to swap throttle cable, PS pump and modify the wiring harness but the valvetrain issue is what i'm really worried about. if anyone could give me some direction here i'd appreciate it, thanks.
