Hey guys I have been doing some research on swapping out my stock 3400 valve springs to Ls1 springs. I've orderd 12 Ls1 valve seats, and just orderd my 3.1 MPFI vin "t" valve seals, and am about to pick up a set of the Ls1 springs. I am not planning to do any type of cam shaft modification, so my question is, are there any other items I will need to make these work on my 3400, or will it be a clean swap with the parts mentioned above. I know there are other threads on the topic but they are not 100% clear to me. I am having a shop install them while the head is torn down to replace a bad hydraulic lifter. Your help is much appreciated.
LS1 valve springs on a 3400
Are they the GM copper colored seats? If your heads are 00 or newer they will need to be ground out in the middle or the valve guide modified up top for them to drop in. Otherwise they drop right in and there is nothing to it really. Using those seals I would say you have the older heads that they drop right on no problem.Ben
With those parts it will be a simple drop in installation. No modifications required.
And they didn't change the valve guides until the end of '00. How many times do I have to say it?'97 Grand Prix GT 3800 (sold)
Gotta love boost!
Parts book says 00-04 so id rather stick to that. Sorta like saying 94 was the first year for the 3100 when its 93.5 olds cutlass really. I would imagine you are saying late 00 based on the actual cars that got them in late 00 due to using up stock from 99 in the 00 cars. I guess looking at the valve stem seals would give it away. Older are orange, new are blue right?Ben
The LS1 shims do work on a 99, but some clearance work May be needed. I had some slight variances on the valve guides that made me open up the ID of a few LS1 shims...
See:
Welcome to our website! Discover a range of top-quality products and services tailored to meet your needs. Browse through our pages to see how we can add value to your lifestyle. Join us in a seamless shopping experience that combines convenience, affordability, and speed. Explore more with us!
Originally posted by sappyse107Parts book says 00-04 so id rather stick to that. Sorta like saying 94 was the first year for the 3100 when its 93.5 olds cutlass really. I would imagine you are saying late 00 based on the actual cars that got them in late 00 due to using up stock from 99 in the 00 cars. I guess looking at the valve stem seals would give it away. Older are orange, new are blue right?'97 Grand Prix GT 3800 (sold)
Gotta love boost!
