I have a 91 Z24, every time I have to add coolant, it takes hours to bleed the air out of the system. I developed a hole in my heater core and connected the two hoses together to get home and it took 3 hours to bleed the system, the same thing happened when I replaced the lower radiator hose. I replaced the vent tube that goes from the top of the thermostat to the bottle thinking it was blocked but no luck. Help?
Air in the cooling system
Original post was moved to the maintenance section. Check there for responses.-Brad-
