Okay this is a question for all who really know the 660 engine specs.If I use a large journal 2.8 crank in a 3.4 block are the bearings the same?looking at bore/stroke ratio and rod/stroke ratio this seems to be the mother of all v6 combos.The numbers mimic the 331cu.in. destroked 350 and it would wind like no tommorow.Hooked up with forged pistons and 10psi dual turbo,should produce 330tq. in my 2300 lb mgb.Any thoughts?and is my calc. about the rod and crank bearings correct?
thanks for all the great help.
Rob
Rob
