Does anybody...
  • Does anybody...
    Does anybody have the actual specs for a set of LS1 springs installed on 3400 heads?
    I need max lift etc...
    thanks
    LS1 spring specs on LS1 engine.
    Valve lift .472" intake .479" exhaust
    Valve spring free length 2.08", installed height 1.8"
    Valve spring pressure 76lb @ 1.8" (valve closed) 220lb @ 1.32" (valve open)
    LA1 springs specs on LA1 engine
    Valve lift .436" intake and exhaust
    Valve spring free length 1.89", installed height 1.701"
    Valve spring pressure 75lb @ 1.701" (valve closed) 230lb @ 1.26" (valve open)
    If you take the LA1 spring compression and add .1" for the lower installed height you get 1.36" which is close to the same compression as the LS1. As for how much max lift you can run with the LS1 spring on a LA1, I don't think anyone has checked, seeing as how if you're running more lift than that you should be using a stiffer spring anyway.
    '97 Grand Prix GT 3800 (sold)
    Gotta love boost!
      i believe its floating around here somewhere but its around .490 if i remember correctly. mine is over .500 so i had to ofcourse opt for the ls6
