is a granatelli motorsports MAF sensor really worth it?
That link doesn't lead to a part, just a search.
Quite simply, answer is no. There a lot of other factors involved when changing MAF's and you need to be able to tune your computer to go with it. Otherwise you might run into problems. It's not as simple as throw a new MAF in and get some HP.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
Depending on what engine you have, you can bump up to a 75mm MAF for a few bux. http://60degreev6.com/discussion/vie...&highlight=maf
It works. You need it tuned though.If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
My Dad put one of those MAF's on his 03 Z06 and lost power. Also put one from JET on his 04 GAGT and it gave a code "too much air". He also has the 62mm TB from PFYC.com.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
As Aaron mentioned, anytime you replace the MAF with a bigger one, you really need to make the appropriate changes in the PCM, otherwise, it will effect the performance. Most often in a bad way. There is a table within the PCM which tells how many grams of air is passing based on the frequency (Hz) response of the MAF. This helps the PCM to decide Cyl pressure for spark, and depending on the model of engine, quite a few other things.
Yeah, but supposedly they say the MAF has been calibrated for the car, so no need to tune. FYI, the vette already had the ECM tuned.Andy
I have one, for a replacement if your MAS has gone bad, it's really not that bad for a replacement! I think. also I looked on a scanner and it does richen up the fuel mixture a little? how much I'm not sure. I got mine for under $200 and it works grate! I'm not sure of the Hp differences but I've seen a Camarro with an LS1 gain almost 8Hp on a dyno by installing one! so they have to do something!
Ps. I also have my intake work done!2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
FFP underdrive pulley
GRANATELLI MAF
Ported upper intake
MSD DIS 4 ignition box
MSD Wires and coils (pending)
Venom high flow fuel pump (pending)
I have a 95 Buick ecm that I’m fitting into my car, and this sounds like an issue I'm having, When the car is at WOT the computer goes lean... I am using a 99 3400 MAF for my application and not the 95 Buick one that is part of the TB... What tables do I want to modify in the ECM to fix the too much air problem that it seems like I am having? I am using tunercat software to do my tuning. If you need a table list for the ecm I can get one too.
Originally posted by torq455Yeah, but supposedly they say the MAF has been calibrated for the car, so no need to tune. FYI, the vette already had the ECM tuned.
I have a used one I bought from someone (LT1 MAF recalibrated for grand am with CAI) and I intend to dyno test it with before and after from the stock MAF using the same intake and filter for accurate results. I also plan to dyno and scan it after making changes to the MAF table in the pcm, and I'd like to do the same to an NA car with that MAF if I can find a volunteer around me.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
Since the vette had a tuned ECM, its MAF table was already tweaked with the stock MAF. Changing the MAF mean't needing the corresponding MAF table to go with it.Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
tuning aside, upgrading to a bigger MAF sensor isn't really worth it unless you have run out of bolt-on's or are running boost.
in either case, i think you'd be better off getting a 85mm ls1/ls2/ls6 MAF off of ebay and buying/tuning that as it is a ton cheaper than the granatelli one.The Official Rotating Mass Nazi
I fully agree. I was running a stock MAF up to 11 PSI, and coulda pushed a lil more.
